  1. Here’s the deal... I rip a movie and I can’t stop the freakn Director from talking through the whole movie. I cut it off in the menu but he still talks. I use SMART RiP, then ifoedit, and then instantCopy to burn. If it’s a mpeg2 or 1 it doesn’t matter. How can I stop this in the future?
    ThanX!
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    incorrect language stream selected?
    The Dutchman
    Dec 2002
    You have selected the wrong launguage stream. Usually it's the 'bottom' audio stream, English 2 Channel. You do NOT want this stream. Try the 5.1 6 Channel stream that is usually the top selection. You can leave it 5.1 or downconvert it to 2 channel.
    Since you mentioned IFO edit, I assume you are making a DVD backup. Simply don't rip the directors audio.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. Thanks for the tip... i have tried what you said to try but i didnt know what i was doing. Plus, Samart rip deselected the movie and wouldnt rip... hopefully ill fix this problem in the future due to your help.... thanX!
    :P
