I have two Xvid files and intend to convert it VCD, but before that I need to join them together.
So my question is should I join before or after the conversion? Speaking of quality, does it really makes a different?
Joining and cutting is easier with Avi's than mpegs (usually) and faster too. Virtualdub is simple, load in part 1 then select append avi to load the second, set both audio and video to direct stream copy, save avi. As long as both parts have the same characteristics (res., codecs, fps etc.) then it's easy. 8)
"Art is making something out of nothing and selling it." - Frank Zappa -
Troncano, this is what ZippyP is talking about:
https://www.videohelp.com/virtualdubedit.htm#join
Hope That Helps!!!
:P
What if both avi have different res and bitrate? Will it still possible to join together?
After encoding only I'm afraid.
The bitrate doesn't have any effect on whether they can join or not. If the resolutions are different, you can't join them together.Originally Posted by Troncano
join problem
By Mesqueeb in forum ffmpegX general discussionReplies: 2Last Post: 15th Jan 2012, 06:06 -
Simple question....... what is the best way to join AVI files
By True Colors in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2010, 22:22 -
Question how to directly join 3 clips with Virtual DubMod
By jimdagys in forum EditingReplies: 6Last Post: 5th Jul 2009, 22:42 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 08:21 -
Question how to join 4 mpeg1 files
By jimdagys in forum EditingReplies: 5Last Post: 28th Sep 2008, 22:18
