  1. "Has anybody had the problem with the newer versions, since cce 2.50.01.00 is being controlled by EclCCE, that if the output folder has a space in the name, which it auto generated, that it fails to run CCE and CCE just hangs when it starts? Also higher versions of CCE give the error that they cannot find the ecl file. This is prevelent on the movie Bad Company. On a side note...if you use a version higher then 2.50.01.00 of CCE does it always ask to save to "noname" when run?" Is this true seen it somewhere else?
    _________________
    Thanks alot,
    dreadogg
    P.S I started this post because it seems that we have ran out of pages in the last thread.
    Thanks alot,
    dreadogg
  2. Hi
    Use a different version of CCE 2.6x and you wont get the message 'save changes to noname'
    Chatwalker
  3. I wonder who does use a none cracked version on this forum.
  4. no wonder why it does not happen to me! LOL
    Thanks alot,
    dreadogg
