i get a weird popup on my computer about 3 times a day saying it is a "messenger service". it always advertises something and pops up like a grey classic grey window. i hit ctrl,alt,dlt and choose show process and it says crss.exe and its listed under system. when i try to end process it says its a critical system file and cant and when i search i cant find it!!!
anyone know how i can find and delete it?
If you have windows XP there is a function that allows network admins to send you a message through a msgbox, but also anyone who has your IP can send you one. I think the service is called "Windows Messenger" disable the service and it should stop it. Many spammers know of this feature and now do mass spamming using a IP scanner.
A bird in the hand is worth a foot in the tush-Kelly Bundy -
Bizarre Premiere Pro bug that I can't find a workaround for
By Asterra in forum Newbie / General discussionsReplies: 8Last Post: 28th Jun 2011, 20:46 -
Computer keeps trying to load some weird ntload.dll file
By jyeh74 in forum ComputerReplies: 40Last Post: 28th Dec 2009, 08:41 -
weird computer problem
By lordhutt in forum ComputerReplies: 5Last Post: 1st Dec 2009, 15:45 -
By deadrats in forum ComputerReplies: 23Last Post: 24th Jul 2009, 19:10 -
LCD displays weird pop-up box
By smile_03 in forum DVB / IPTVReplies: 1Last Post: 8th Jan 2009, 22:57
