Results 1 to 9 of 9
  1. i have a problem that occurs when i click on a link that opens a new window. i click on it and the new window opens but it wont load i let it wait for like 10 minutes and they still wont load, btw i have a dsl connection so it should take a while to load. i havent had this problem before i just got home from a week in cali and this started happening i dont know if someone else changed the settings or what. please help thanks
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Not sure why you would want them to load, but make the fact that they are actually being opened tells us that it's not the fact the javascript is turned off, other wise the windows would have never been opened in the first place.
  3. well technically its not a popup just a link that opens in a new window. the window opens but it wont load. please help.
  4. Im having the same problem aswell. If anyone knows a fix please post.
    btw im on AOL, are you?
    Cheers
  5. no im useing internet expleror
  6. thanks for the help but i figured out how to fix it.
  7. Mate could you mail me telling me how youy fixed the problem. Thanks
    head_phat@hotmail.com
    Cheers
  8. Free Flying Soul liquid217's Avatar
    Feb 2002
    it may be a problem with BHOs (Browser Helper Objects) in Interner Explorer. Download the program below and click scan. WARNING, be careful what you remove, some of those are default and shouldn't be touched (example, the HKLM entries). This is a very handy program for removing plugins that are installed into IE by accident that could interfere with your use of IE.
    http://www.spywareinfo.com/~merijn/files/hijackthis.zip
  9. nah all i did was i went to add/remove programs and clicked on the button change/remove and then it poped up with a new window and just ran the repair internet expleror and now it works fine.
