hi, i juss got a normal sized movie svcd, which is 3 mpegs files long..each just a little over 700mb.. if i use tmpgenc and convert it back to ntsc film, will it the file be about 1.7 gb? and will i lose a lotta quality? thnx.
You seem to be asking two questions, so first a little back ground.
MPEG file size is determined by two factors: bitrate and soure runtime. These are the ONLY factors that affect the file size. Resolution, frames per second, source file size, etc. have no affect on the size on the encoded MPEG file. They do however affect quaility.
As a general rule the higher the bitrate and resolution the better the quaility of your encoded MPEG file (if your source is good). With that in mind the standards are:
VCD - MPEG1 352x240 @ 1150kbit/s (audio mpeg1 layer 2 @ 224kbit/s)
SVCD - MPEG2 480x480 @ 2520kbit/s (audio mpeg1 layer 2 @ 224kbit/s)
So what makes SVCD better than VCD, is the higher bitrate and resolution. If I made a xVCD: MPEG1 480x480 @ 2520kbit/s it would look the same as a SVCD.
So to answer your question. If you convert a SVCD to VCD, you'll lower the bitrate and those the file size (for VCD 1min=10MB of data). The quaility will also decrease because it's a lower resolution/bitrate.
However, changing the frame rate (film vs. NTSC) will have NO effect on file size. Hope that helps... -
Originally Posted by madeyalook
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 17:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
