When I try to load my downloaded movie file in TMPGenc it says "it cannot open the file or that it is unsupported". What do I need to get it to work please.
Fist of all wot type of file is it . AVI . MPEG-1 . MPEG-2 . Have you got the right codecs installed etc
G Spot says it is a SMpeg 4 version 3 video format and that the codec is installed.
I currently have the same problem, make sure to post what you did if get it fixed. There are some tips under conversion on the left if you look under 'using TMPGE'
If you are sure the right codecs are installed and it still won't work try re-installing them, could be bad.
I don't know where to install them from, whether they came with the pc or downloaded from somewhere. I am not that technical.
@barb210:
semms you're not even a userI don't know where to install them from, whether they came with the pc or downloaded from somewhere. I am not that technical.
let's make things a little bit simpler... can you play the file with windows media player?
yes -> codecs are installed
no -> codecs are not installed
nevertheless, i figure what you mean could be "MS Mpeg 4 Version 3" and if so, i'm afraid it might be a .asf file, and if so further, you will not be able to open it in tmpgenc.
if it is an .avi file, you might want to get a "fourcc changer" (-> don't ask me where to get one, ask google please) so you can change the format to divx or xvid.
after that (and if you have a divx/xvid codec installed) you can open the file in tmpgenc.
bye,
--hustbaer -
Thanks for all your help all is okay now, the problem was a windows media update that seemed to knock everything out, I have now restored it to a previous time and all is okay.
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 19:26 -
encoding .3GP. Need help. Urgently.
By navand in forum ffmpegX general discussionReplies: 2Last Post: 6th Jul 2011, 14:35 -
Help needed URGENTLY!!! "download DBCodec"
By Liaaggelou in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2010, 12:40 -
Authoring Help Urgently Needed
By AlanSibley in forum Authoring (Blu-ray)Replies: 11Last Post: 3rd Dec 2008, 01:20 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
