Hi,
I've just recently used EOVideo to convert RM to MPEG but I find that there is a slight lag or outta synch between the audio & video after the MPEG conversion...is there a way to correct this? or better yet...prevent it from doing so?
btw, is there an EOVideo tutorial somewhere in this forum?
Thanks!
You can try export the RM to AVI first, then encode to MPG. If the audio is out of sync then, you can easily fix this in any video editor then encode to MPG.
yeas try converting to avi first than to mpg. Its easier to fix problems in avi than in mpg, there are a lot more tools.Originally Posted by Faceman101
Thanks guys!
I'll try it. I assume when you say Avi...uncompressed right? Well, I guess VirtualDub can do most of the corrections later...
Which one is this app? AudioVideo Synch?
By CactusMan in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2012, 07:31 -
Correcting colours in CS4
By sterankin in forum EditingReplies: 2Last Post: 6th Sep 2011, 06:24 -
AVI audiovideo in and out of syn
By graveller39 in forum Video ConversionReplies: 3Last Post: 28th Mar 2009, 13:00 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
Correcting VCD aspect ratio?
By gastrof in forum Video ConversionReplies: 4Last Post: 30th May 2007, 15:43
