learning to burn movies to one cd I read some post and posted some questions from all that I have gathered I am attempting this ... and one big question comes to mind,, going with the what seems to be the best info and suggestion I have set up a template as 900 bitrate and 192 audio bitrate with a 2 pass vbr I know that they said this would take longer but would help to keep the quality better. and the post said it was taking him like 10 hours compared to regular 4 or 5 hours.
So my question is I have a approx. 90 minutes movie I am going on 14 hours of converting and I am only 70 percent done. does this sound right? or might I be setting some things wrong.
My system is 1800+ amd
512 meg mem.
geforce 4 ti 4200 video.
Just wondering because the person said their machine was a bit slow and it was taking them 10 hrs.. and being that im on 14 and only 70 % good Lord my machine must be REALLY slow.
Results 1 to 12 of 12
Your spec's suggest your puter isn't slow by any means. Have you loaded a load of filters for your encode?.
I have similar specs' to you and if I load o load of filters it takes me 10-15 hours to encode a 90-120 min' film to SVCD using 2 pass. -
Athlon 2400+, W2K, 512 MB DDR RAM. I encode overnight. 2-pass VBR to 2-3 disks, full audio conversion of the 5.1 soundtrack. Typically it takes 8-11 hours from ripping to final bin/cue creation.
Here's a BIG tip. In you motion precision, do NOT select the highest setting, this only doubles your encode time. Try the #2 or even #3 setting. The 'normal' motion search precision does a pretty good job, it jsut depends on the movie (slow chick flick versus fast action flick). This greatly speeds encoding time (at the cost of quality, but I can tell no difference between highest and second highest).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
What are you converting from to and what are you using for the conversion.
If its say DIVX to MPG2 wiith 2 pass, 10 hours seems a little long, but not unreasonable. Are you running any other processes? -
Have you had a look at the speed setting 'Motion Search Precision' obviously the faster the lesser quality and so on. 14 hours doesn't sound that bad , i tend to use CBR not VBR , as u say it takes almost twice as long with that setting.
I just did a 2-pass VBR all on one disk VCD, 90 min. movie. Motion Search set to slow, sharpening 30-30, soften block noise 35-35, 1.6 GHz. Athlon...it took 4 hrs.
There is a setting in TMPGEnc under environmental settings to cache the first pass. If you have the room this should be set to 5 GB. or so. That setting cut my encoding time by 25% at least. It might only be in TMPGEnc plus though, I'm not sure.
Any other filtering will greatly increase encode time. Are you running anything else in the background?
"Art is making something out of nothing and selling it." - Frank Zappa -
Wow thanks guys alot of good info here , appreciate it alot, will try some different settings.
And for those that was wondering I was converting from a divx to a mpeg file and as for filters the only filter I was using was the noise reduction filter. but everything else was default so I will look into those other things mentioned.
and again really appreciate all the good advice!
Yes, the noise reduction adds a lot of time.
Alternative: use the noise filter in Vdub and frameserve to TMPGEnc instead!"Art is making something out of nothing and selling it." - Frank Zappa -
ZippyP, I've tried that frameserve with noise filter thing but didn't manage to get the kind of results I can get using TMPG's noise filter (although it was much quicker).
Can you tell me which V/dub filter you used and a rough guide to your settings so I can try it properly?.
Cheers -
One thing that seriously affected performance for me once, was I got low on disk space, and that spaces was quite fragmented.
An encode that typically takes around 4 hours took 9 hours. Clearing some disk space, and it went back to normal.
It might help you, it might not. -
I'm looking to get a new computer soon but right now if it would only take 10 hours to encode a movie I would be grateful. I am using an AMD 533 256 RAM and it takes anywhere from 18 - 35 hours to encode and that is without using filters of any kind. So, 10 hours is not a lot of time when you look at how long it takes for me. I know others on here have faster computers and it doesn't take them near as long.
I don't normally use noise filtering unless the clip I have is very poor quality. Here's a thread that might have a few tips for you as well as links to other discussions: https://www.videohelp.com/forum/viewtopic.php?t=148978Originally Posted by ABAB
8)"Art is making something out of nothing and selling it." - Frank Zappa
How long does a camcorder last?
By Schtil in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Oct 2011, 05:47 -
Is Movie Maker suppose to be slow?
By videohalp in forum EditingReplies: 3Last Post: 22nd Aug 2010, 11:51 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 08:41 -
A long overdue thank you
By epj16706 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 22:03 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08
