Hello,
So my PC (1.6Ghz, Win2000), started running slowly all of a sudden
last week. Documents and programs will take a while to open, and will
also pause while I'm using them.
I stumbled on the Win2000 resource meter, and found my pc's
resources were up to 100%. Long story short, after killing off some
processes, and uninstalling some programs, I still had the same problemo.
Finally, I killed a process called "regedt.exe", and everything went back
to normal. Is this a virus or malware of some type?
Anyone else experience this?
You sure it was not regedit ? Regedit is the systems registry editor.
Yea, it was regedt.exe
I thought that was weird, too, that's why I thought it was malware or a
virus of somesort. I'm running a current version of Norton, though.
I did some research on regedt.exe, but haven't found much. -
Well, there's a regedit.exe (new-style registry editor) and a regedt32.exe (old-style registry editor). I think regedt.exe is an even older registry editor from the 16-bit days, and you shouldn't normally be seeing it on a current version of Windows.
But none of those programs should normally be using any amount of CPU time unless you're searching registry keys or something like that. -
yea, it's a (fairly) new pc. I was kind of doing process of elimination,
and killing off processes to see if the usage meter would drop. As soon
as I killed off regedt.exe, it dropped. The pc was absolutely fine the
whole rest of the day (and it's been like this for over a week). Although,
near the very end of the day, the usage went back to 100% even though
regedt.exe wasn't open. I rebooted, and closed regedt.exe again, and
everything was fine again. Grrr. -
Looks like a virus or trojan to me. I'd delete it and all references to it in my registry. The fact that it runs at startup only reinforces my belief.
Killing some unwanted clips
By jairovital in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2010, 08:22 -
Power cuts killing PC
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 11th Feb 2010, 08:55 -
new anyvideoconverter freeversion 3.0.1 is killing me.Need help please!!!!!
By tendra in forum Video ConversionReplies: 3Last Post: 16th Dec 2009, 07:27 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 09:42 -
Bollywood movies keep killing my DVP5982
By gene0915 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 10:16
