I have noticed that this version is a bit faster compared to the previous ones. I have a movie which took 15 hours to encode. With version 12i, it took 24 hours to encode the same movie. However, the resulting VCD-MPEG1 output of this latest version is CHOPPY. Has anyone encountered this problem?
I just compared the speed and output of 12f and 12j.
12j is 20% faster than 12f. (24'52" against 31'01"
I cannot see much (quality) difference between both generated MPeg streams.
What exactly do you mean by choppy ?
What I mean is that the encoded movie (VCD-Mpeg1) is not smooth when played back on my PC or Pioneer 535 DVD player.
I noticed that it is jumpy. Like I said, I have encoded the same movie with 12i and it plays great. But I want to use 12j for now because of its speed. I just want the jumpy or choppy (whatever you call it) problem to be solved. -
do you think that maybe you had "slow" or "slowest" set when you encoded in your previos version and have "normal" or "motion estimation" set now? it would explain the extremely large disparity in encoding times (going from i/h to j wouldn't be enough by itself to go from 24hr to 15hr)
Hi i have exatly the same problem i have just tried to use version 12A to see if that helps.
if you find out why please mail me :O)
vcd_screeners@hotmail.com
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 08:09 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
Help With Choppy DVD
By hgsouth in forum Authoring (DVD)Replies: 7Last Post: 13th Apr 2008, 00:18 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 23:32 -
DVD is choppy!
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 11th Dec 2007, 22:56
