As I understand it, the max bitrate for a XSVCD is determinated by the CD-read-speed in the DVD-player, right?
But if I create a DVD-XSVCD, the DVD-R is read as a DVD. And a DVD-read-speeds are often faster than CD-read-speeds, right?
So if my DVD-player just can play 3000 kbps XSVCDs if they are put on CDs, it's possible that it can read more than 3000 kbps if i put them on DVD-Rs, right?![]()
Guest
Ummmmmmmmm, no. The CD read speed is one limitation, but this is usually at least 8x (ie a 1x DVD speed). That's roughly 10,000 which is a respectable bitrate for a DVD video.
Your limitation is your DVD players ability to deal with the data. Some players choke out at 2500, whereas mine keeps plugging with xSVCD's at 6000. It chokes at 8000.
You can't put a xSVCD onto a DVDR, it doesn't work like a SVCD. You can put it on a DVDR as an MPG, if your player supports file mode play (mine does, but it won't search/FF/REW in file mode, only in VCD/SVCD mode). What you really want to do is author your DVDR's in 1/2 D1 mode. This gives you about 1/2 the resolution so you only 'need' 1/2 the DVD bitrate. Realistically you can get some pretty high bitrates and still have a 3 hour movie on 1 disk, with subs and 5.1 audio.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 09:31
