Im looking to put some tv shows onto cd but they are in a weird format that I dont know or cant find info on, they are mpeg files but in vdub info page they say...
frame size 176 x 120 30.000 fps (33333 )
there is the other info also but not like I normaly see like no codecs is listed on numbers for p-frames b-frames and some others (dont know if this info is usefull to the question) and then the audio is
44khz mono 64 bps layer II
my question is how can I get these back to something I can put onto a cd to watch, Ive tried using tpmge to convert but they make HUGE files and they stay exactly the way they are. when i play them in windows player they are just in a small square in the screen if I go full screen the quality is horrible. I also tried just converting to vcd since they are mpeg files but that didnt work either said they would not be able to be played in standalone dvd player.
So I guess im wondering if its even possible to to get them somewhere that I can use them to make vcd's in full screen. I know they probably wont be best quality but thats fine just as long as I can watch them they are just cartoons.
Results 1 to 1 of 1
Power supply numbers
By kenmo in forum ComputerReplies: 11Last Post: 14th Jan 2011, 09:18 -
How To Change Chapter Numbers
By vomiranda in forum Authoring (DVD)Replies: 1Last Post: 5th Jul 2010, 11:46 -
Get the numbers off!
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 22:19 -
Audio/subpic ID numbers
By sambat in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 11:09 -
VLC Vs. ffdshow statistic numbers
By prankstare in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2009, 10:08
