  1. PLEASE HELP. Iīm going crazy really soon. Canīt figure this out.
    Iīve got a RADEON 9000 graphic card, 1700 MHz Celeron and a Panasonic widescreen 100hz TV. The picture I get when I playback video on the TV is fine (no jerkystuff and the sound is fine) but whenever the camera pans or something moves by (cars, people, etc.) I get these irritating lines behind the moving object. Itīs like the TV canīt update the picture fast enough and is a little behind with some of the lines.
    As far as I can see the picture looks fine on the computer monitor.
    Hope someone can help.
    Thanx.
    -Zacron
  2. How are you capturing, converting etc? VCD, DVD, SVCD?
  3. Ups, sorry. Forgot to tell that Iīm using Media Player and itīs all formats thatīs a problem (DivX, Xvid, MPEG2). Iīm not converting or compressing, just decompressing (playing).
    -Zacron
  4. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    are you on an NTSC TV system? i found with my custom TIVO set in NTSC mode that if i watch a 23.976 fps movie (such as DIVX is usually found) then i get these artifacts because the image is not teleclined. (converted to 29.97 fps, the NTSC TV standard)
  5. No, Iīve got a PAL TV system. Just call me a newbie (cause I am) but what is TIVO?
    -Zacron
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    ah, you're pal. ok, check the files you are playing, they need to be 25fps to play smoothly. open one up in media player and click view - statistics. it will tell you the framerate. like i say, through a TV out anything other than 25fps will cause a problem on a PAL tv.
    TIVO is that silver box thingummy that lets you pause live TV and record stuff to watch later. i have a mini pc for this, complete with TV out and dvd-burner.
