Hi Folks!!
I am trying to import a .m2v-file into DVD-Maestro. When i am dragging it into the video track, i got the error message:"The Video Asset Length is greater than the maximum allowed". The Length of the file is 1h:55m:08s:17f and its size is 3.9 GB.
Thx for your help
best
_Trinity
The only thing that comes to mind is that perhaps you are working with a project file that has been created to write a smaller DVD file and not the normal 4.36 size.
The more I learn, the more I come to realize how little it is I know. -
hmmm...I don't really think so...
i'm runnin the standard settings...
dvd-rom, one sided, 12 cm
didn't have anyone this problem??? -
DVD-ROM?Originally Posted by _Trinity
I have gone through the DVDMaestro help file and seen that it can do DVD-ROM, however what you want is DVD-Video. The help file mentions a few differences between the two formats.The more I learn, the more I come to realize how little it is I know. -
Well known problem... Somebody's "crack" program corrupted part of the program.
What version of DVD Maestro are you using? If you're using version 2.5, it is not compatible with Windows 2000 or XP. You'll need version 2.9 if you are using one of these OS's.
I tried version 2.5 with W2K and I got the same error too. As soon as I switched over to version 2.9, it worked great. -
@cellmaniac:
maybe you're right! i'm using version 2.5 running windows xp!
trying to use 2.9...
thx a lot for your help!
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 21:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59
