  1. it seemthat the ND-1000a seems to only exept good quility DVD+r like infinite if you use cheaper ones thats when you get the power calabration error it seem like its down to firm ware i used bulkpaq DVD and every one came up the same error http://www.bulkpaq.co.uk/ have a look it seemes its not the only wrighter that suffers from the same problem on that sight it explains the problem a bit better look at the pioneer one in the info bit im thinking of sending mine back ive sent a email to nec but thay will probarly not repley but if thay do ill let ye know whats happning + i didnt know you can burn DVD-r in the nec ND-1000a are you sure a thought it was just +r it took but mind u im new to this so some one please help me out here im real stuck
    Oct 2002
    Wisconsin, USA
    I kept getting a power calibration error too, on every DVD+R I tried to write. I could burn VCDs, SVCDs, and even DVD+RW with no problem. I just couldn't burn a DVD+R...not even Verbatim. Finally, I took it back to Office Max where I bought it and got a different one. Haven't had a problem since.
    My suggestion is to go buy some good media and try again. If it fails again, take it back like I did.
    Vanster
