Hi...
Please could some one help me...
Iīve read all the forum answers to how to convert xvid to svcd, and nothing works, the tmpgenc doesnīt work, I donīt know why, and if it starts to convert, after the first 15 min. the movie becomes black and it converts everything to black...
Please help me
Results 1 to 10 of 10
Can you play the file on your PC? What does Virtualdub say under File Information? Did you scan and remove bad frames? There are guides on this site for that.
"Art is making something out of nothing and selling it." - Frank Zappa -
no, I canīt everything is green, but the sound is ok, and the movie is in the back of the green screen
You don't have the necessary codec installed on your system. Get Gspot form the Tools section and use it to test your file. It will tell you the required audio and video codecs, get them and install. You can get codecs from the Tools section or google search. 8)
it still doesnīt work.
I install the program and run it, it said that no neceseary codec nedded, that i had it all in my pc
the image is still green -
A copy and paste of one of my previous post replies.
4CC Changer.
I use this baby all the time to change my temperamental XvidS' to divx, I've not had one bomb out on me.
Make a copy of your film (maybe onto the desktop).
Open 4 CC and browse to your copied film.
The description code should say 'xvid'....type 'divx' into the 'used codec' box and hit apply............a nano second later your copied film can be used as you like. If all is well don't forget to delete the original.
Here's the link.
http://www.divx-digest.com/software/avifourcc.html -
I agree with ABAB....if I get an Xvid movie I always use the Four CC changer and I don't get problems with Xvids anymore.
...or try ffdshow. It allowed me to play XviDs without all problems like pixelated green images and stuff. Never had to "cheat" by changing "xvid" to "divx" since...
/Mats -
Sounds like you have an XviD, not a DivX. Also sounds like you are using the year old codec from Nimo. It's a codec issue, get the latest XviD codec release.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thank you for the advise with 4CC, now I too has no probs with the xvid.
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 19:27 -
how do I make a DVD with Divx or Xvid videos and have a menu that works
By Onceler2 in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 20:14 -
Convert Xvid versions to Xvid 1.1.2
By mdavenport in forum Video ConversionReplies: 23Last Post: 11th May 2008, 19:01 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 18:50 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55
