If I use tooLame as the audio encoder in TMPGEnc , do I have to covert the audio to a wav file before hand? Or is the tooLame encoder used only for sound quality issues?
I'm new at this so I'm a little confused at the momment??
Results 1 to 24 of 24
Originally Posted by dimsnavi
Load your Avi into Virtualdub, select under Audio: Full Processing Mode, compression - no compression, conversion - 44.1 KHz., then under File - Save Wav.
Takes a couple of minutes only. 8)
P.S. If you get a VBR warning then you need to use VDUB-MP3. If your files has AC3 sound then you can consult a guide on this site for conversion to wav. 8)"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by puertorican138
i ask this because i tried to convert a short clip(with toolame) without making a wav first and i didn't get a message that something was missing. however the clip was really short and i didnt pay much attention to the sound quality... -
Well I extracted the audio to wav first - which took next to no time - and then encoded - came out perfect, no sync problems what so ever.
Thanks for the imput guys! -
I know I am just being pedantic but I believe I am correct. -
I to was wondering about things like yours.
But instead of extracting the sound from the avi, I've found a good and nice solution to it.
Find a program called Honestech mpgencoder 4.0, use it to convert the avi to a mpeg-1 file, it wil take a while depending of the size and quality of the avi.
After you have done that, just convert it to mpg for VCD with Tmpgenc.
Honestech can make a full conversion, but sometimes it will be with a sync problem at sometimes with some pixel errors.
Hope you can use my advise. -
kimmi:
could you give me the CD key and the serial for <edited - no warez requests> , works ok, but it doesn't load the audio from .avi files, do you know why?
thanx! -
that's one I've never heard of before.
Is it any good??? I'm always on the lookout for something better/faster than TMPGenc...although so far I've found nothing better -
HEYYYYYYYY...what the F*** do you think you are doing editing MY post?????...granted the guy above me was asking for a serial number...but I was just enquiring whether or not a program was any good...NOT if I could pirate the frigging thing!!!
What a twat. -
Honestech????????
Is it any good??? I'm always on the lookout for something better/faster than TMPGenc...although so far I've found nothing better.
THAT was my post above which you edited...tell me where the F*** I was requesting warez!!!!....its very simple to understand...I was asking if it is any good...NOT where I could get it for free....you can read yes? -
Originally Posted by antoniosgubba
your post was ambiguous - thats why i didnt lock it altogether , your question is still there ..
thanks
Go ahead and lock it then!!...if it gives you some power trip to do so.
You've needlessly edited several of my posts before this as well... ambiguous???...how so?....is asking if a program is any good not allowed then?? -
i remember you -- the one who claims he got XVID format dvds from Amazon -- hahaha
if you cant figure it out from your own post - i'm sorry ..
there is nothing personal , just following the rules of this site (and owner) .
if you have done nothing wrong - don't sweat it , lot more importaint things in life to worry about ..
as i mentioned in the past - have a nice day and move on to something else.. -
Erm actually....I didn't claim anything of the sort...if you look at that post again you'll see that you stated a DVD was not yet legally available...I showed you that it WAS.
If you aint big enough to apologise for needlessly editing my post about Honestich then I don't really give a toss to be honest.
Anyway, I just tried Honestich and it SUUUUUUUUUUUUUCKSSSSS!!!!!! -
yes --- i agree , honestech really is not that good compared to CCE basic or Main Concept or even Ligos for encoding -- im not sure if it is any faster than tmpgenc , but its quality and ease of use where no match to tmpgenc ..
HEY...now you're making me feel guilty!! I was sort of expecting you to have a go back at me....not agree with me!!
Originally Posted by BJ_M
i'm sorry, i didn't mean to... i was hypnotized by bad people..... -
I can see I got a problem now, because I'm not sure if I might say what I say, but I hope this is allright.
Just look for the program with overnet, you will find everything nedded.
I use the program everyday now and I have no problem, what so ever it could be.
I hope it helps you and that my answer not wil be altered. -
its all done, i bought (you dont believe me??
) the program and i tried it and all...
but its very simple, not much options...
+ i thought it will solve the jerkiness problem i have with tmpgenc, but NO, the svcds are jerky with honestech as well
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
