  1. when i try to put the mpg into reeldvd i get
    Error ReelDVD only supports 4:3 or 16:9 video
    Anyway to fix this without using tmpg thanks for help
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Sounds like your video's resolution isn't standard. Use the MPEG Properties software (you can find it in the TOOLS section to the left) to examine your MPEG. It should be one of the standard resolutions for VCD, CVD, SVCD, or DVD (you didn't say which format your trying to create).
    Refer to the 'What Is' section at the top left of your browser to see what resoutions each format supports.
    Impossible to see the future is. The Dark Side clouds everything...
