I just got a Dell Dimension 8250 with a NEC ND-1100A DVD+RW drive. I have been trying to use VCDEasy to burn a VCD, but it tells me it can't find the right driver. First it told me it couldn't find a drive, but I used the Force ASPI tools and now it will at least recognize the drive, but I don't know what driver to use. I tried the Generic MMC driver, but I got a coaster out of it.
Has anyone with this drive been able to successfully burn using VCDEasy? If so, what driver did you force it to use?
Thanks,
Brian
I have not had experience with your drive, but I would say to try generic-mmc-raw and make sure force execution is checked. Generic-mmc and generic-mmc-raw cover most IDE CD burners.
I got the same system as you & i haven't got VCDEasy to burn to my drive. Its no big deal just use it to create a bin image & burn that with any number of burning applicaions. I use Alcohol 120% for this.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the info everyone.
I used the generic-mmc-raw driver and made sure Forced Execution was checked and it worked fine. I appreciate all the help.
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
How do you get VCDeasy to work on Windows 7 Ultimate (32bit) ?
By DragonLord721 in forum Newbie / General discussionsReplies: 10Last Post: 24th Nov 2010, 09:44 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 18:18 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11
