I tired to use Tmpg and CCE and they both won't except the Mpg-2 file......I got the nemo codec pack.....Will someone please help me this is really frustrating
Results 1 to 12 of 12
This is the original log if it would help anybody figure out my problem
GENEREL INFO
- Source: DVD (NTSC)
- Movie Offset: 2 sec
- CD Overlap seconds: Yes, 2 sec
- Startup delays: Video: 180 ms Audio 1: 180 msAudio 2: 180 ms
- Video format: NTSC
- Length: 01:53:31
- CD Images:
IMDB INFO:
Movie title:
User rating:
Directed by:
Writing credits:
Genre:
Tagline:
Plot outline:
VIDEO INFO:
- Encoder: Cinema Craft Encoder 2.50.1.0
- Encoding mode: Multipass VBR
- Passes: 2
- Max. bitrate: 2530
- Avg. bitrate: 1688
- Min. bitrate: 300
- Image Quality Prio: 17
- Antinoise filter: No
- Linear quant. scale: Yes
- Zigzag scan order: Yes
- Upper field first: Yes
- Progressive frames: Yes
- iDCT Algorithm: 32-bit SSE MMX
- Resize method: SimpleResize
- Temporal smoother: No
- Sharpen: No
- NTSC Field Operation: Force Film On
- Deinterlace: None
- Pulldown: Yes
- Matrix:
Intra:
8 16 19 22 26 27 29 34
16 16 22 24 27 29 34 37
19 22 26 27 29 34 34 38
22 22 26 27 29 34 37 40
22 26 27 29 32 35 40 48
26 27 29 32 35 40 48 58
26 27 29 34 38 46 56 69
27 29 35 38 46 56 69 83
Non-Intra:
16 16 16 16 16 16 16 16
AUDIO INFO:
- Audiostreams: 1
- Audio 1 Language: English
- Audio 1 Bitrate: 224
- Audio 1 Sample freq: 44100
- Audio 1 Mode: Stereo
- Audio 1 Besweet: "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -g max ) -ssrc( --rate 44100 ) -2lame( -e -b 224 -m s )
SUBTITLE INFO:
- Subtitlestreams: 0
- Type:
- Sub. 1 Language:
- Sub. 2 Language:
- Sub. 3 Language:
- Sub. 4 Language:
AUTHORING INFO:
- CD Image program: VCDXBuild
- Entrysvd: No -
Exactly what are you trying to do with these files? You say TMPG won't edit them. TMPG is not an editor. Neither is CCE.
If you want to re-encode the film try frameserving from DVDx 2.2. It is freeware available in the tools section on the left. You will also neef the video serverpack 095 available at www.doom9.org. You must install this before you can use DVDx as a frameserver. DVDx will import mpg files and export avs and avi files. TMPG will accept avs files if it (TMPG) is configured right. I'm not sure about the version of CCE you are using, but the avi wrapper available in the video serverpack can be used with DVDx to create a dummy avi file that will be accepted by both TMPG and CCE.
Where is the Server pack you mentioned can u direct me better....doom9 is sorta confusion.....thanks for your help too...also when trying to open the mpeg in dvdx it said it didn't have a header...maybe something along those lines..thanks again
The video server package is in the download section under s/vcd tools at the doom9 website. It is called the videoserver plugin 0.951. As far as your mpeg file not having a header, try using dvdpatcher. I've never used it before but I think it can be used to fix header problems. It's in the tools section on the left under other useful tools.
Has anyone asked if you've installed the required MPEG-2 codec? It looks like your source was DVD, converted to SVCD/CVD.
Have you installed something like WinDVD, or PowerDVD? VirtualDub will often report that error when attempting to open MPEG-2.Impossible to see the future is. The Dark Side clouds everything...
ffvdub or ffdshow encoder image processing doesn't work with VirtualDub?
By Milardo in forum EditingReplies: 42Last Post: 21st Jan 2011, 18:09 -
Capture Cards that work with Media Encoder 9.0
By alec_owen in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2008, 07:26 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 13:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 15:36
