I use HuffUV in VituralDub for transfering my camcorder tapes to SVCD.
I have an AMD 1800 with 256Mg DDR400 RAM and a Seagate 60Gb 7200rpm HDD.
I'm capturing at 480x576 in VDub. The CPU usage in the VDub log only sits around 20% whilst capturing and the compression rate is only around 1.5.
Questions,
1. How do I increase the compression rate to use more of the CPU so that I can get more capture time before the HD fills up?
2. My 60Gb is in 2 partitions, C 10gb and D 50Gb
Even with all the data on D drive defraged and moved to the start of the drive I get 2 dropped frames during 10min captures.
I assume it happens when the HD is moving to a new point (1 frame at about 4mins and the other around 9mins, does vary though)
My defrag window shows the same number of fragments as the number of frames dropped during the capture.
What else can I do to prevent frame drops ?
or should I be happy with just 2 or 3 frames per 10-15 mins?
You need nothing to do... 2 or 3 dropped frames are REALLY GOOD ratio!
I am afraid that, with huffy codec, you cant raise the compression ratio of the stream...
try PicVideo codec.
Fredİ
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 04:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 09:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 06:55 -
Help Aspect Ratios & Frame Rates
By CTP-Crystal in forum Newbie / General discussionsReplies: 21Last Post: 1st May 2009, 18:10 -
Dropping frame with profile H.264
By n69 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Dec 2008, 21:41
