I am considering going for a firewire capture card with realtime mpeg2 encoding for capture of VHS material for burning to DVD. I want to go this route because I'd like to be able to do it with little or no quality loss as opposed to analogue capture/compression. I know it will cost a lot of money so want to be sure it will work.
Have just checked my camcorder (JVC GR-DVL150), and although it has DV-out it does not have any analogue input.
However, a good friend of mine has a Sony DCR-TRV110E. Can anyone tell me if this Sony model has analogue input, and if so does it support pass-through or would I have to record to digital tape first then playback to the PC...?
If I can't achieve it with the above camcorder I'll probably forget the whole thing and buy a set-top DVD recorder instead....
My friend has a DCR-TRV730 and that has both analogue in and pass through mode. Try looking online at sony's website to see it's features. Don't worry about it having a pass through mode because there will be no difference in quality if you put it on a tape first or pass it through. The only downside is it takes as twice as long to capture.
Thanks for the info. I did have a look at Sony website but the 110 model must be an old discontinued one because I couldn't see it listed. Some web sites contain user manuals for old products, but couldn't find it on the Sony site.
I will be seeing my friend tonight so will find out first hand what it can and can't do. Seems like I will probably need to start saving up for that capture card soon....
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Cannot capture - DV Camcorder to PC
By kev35 in forum Capturing and VCRReplies: 9Last Post: 8th Sep 2008, 09:43 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 21:52 -
Capture from DV Camcorder
By quxote in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2008, 22:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
