If I create a SVCD slide show by generating a pair of *.img files, is it possible to add a folder of the original larger jpegs to the CD prior to the burn?
--Jerry
So you are wanting to add a folder containing images of higher resolution in a data format that will NOT be displayed on the svcd disc but just as data for computers to read?
I am a little confused, but you might be able to burn the .img files in XA mode and tell it to WRITE SESSION and then add the folder and burn as ISO? I dont know if that would work or not.
If you are just wanting to add the images folder within the SVCD disc structure, i cant think of any way to do it as the only way to burn SVCDs on a Mac is to create images out of the MPEG first. Unless you can find a program to create the right type of image for you that allows non-mpeg content.
I honestly don't know.
[i drank too much last night] blah.
Adding timecode data to a VP8 video at encode-time
By ilya.lissoboi in forum ProgrammingReplies: 0Last Post: 29th Apr 2011, 05:43 -
Adding extra data folders to DVD
By schematic2 in forum Authoring (DVD)Replies: 6Last Post: 25th Apr 2009, 11:01 -
Best multitrack editing software?
By photonianpa in forum EditingReplies: 3Last Post: 5th Mar 2009, 11:05 -
MultiTrack Recording- Out of Sync
By GT Music in forum AudioReplies: 6Last Post: 23rd Apr 2008, 18:43 -
DVD multitrack / DAO
By crazymoney in forum Authoring (DVD)Replies: 7Last Post: 10th Oct 2007, 00:09
