I made some photo VCDs using Ulead Picture show (menus on the front screen), they worked OK in my other players but not in my alba 108.
Anyway, I fiddled about with the remote and got them working by accident.
I don't know whether I have found a hack or if there is an easier way to get them to play, maybe someone else knows another way.
I used the VCD hack - 2812, press enter, push drawer in manually and then hit "1" when yellow square in top l/h corner appears.
I then got a screen up saying "Ulead PhotoVCD, VCD 2.0 player required,
please turn on PBC to show photos"
If you hit "1" while this screen is showing and straight away hit "menu"
the front menu screen appears and the photos can be played from each menu from the numeric pad on the remote.
Alternatively, the whole lot can be played all the way through by pressing enter.
Regards
Jazzman67
