  1. I'm editing video in Windows Movie Maker 2, and then outputting to DV-AVI format (the only non-wmv format available). Then I convert to SVCD mpg in TMPGenc.
    The first video I did I had to choose bottom field first (field B) as the field order - field A gave jerky results. The second video I did (the exact same process), required top field first (field A) to get rid of the jerkiness.
    What's the trick to determining which field order to use?
    Mar 2002
    United States of America
    TMPGEnc's wizard tells you the correct field order to use.
  3. Yep, it sure does. I never used the wizard, so I didn't know it was there. Thanks.
    Mar 2002
    Sure!!! :P
  5. twentworth
    If you don,t know how to do it, check this guide.
    https://www.videohelp.com/tmpgencsvcd.htm
