Hi. Recently I watched a movie on my standalone dvd player, and it played fine. When I played it on another dvd player it kept jumping. I know what formats work because I've played all of them without a hitch. My question is could it be the framerate. The movie is 23.976 fps, and thats what Im encoding it as? Thanks for all of your help![]()
JUMPING?
You mean the picture shakes?Don't give in to DVD2ONE, that leads to the dark side. -
If you played fine on your standalone but not another I would suspect that you are trying to play either a SVCD or xVCD, and that this disc has trouble on your friends player because it was encoded a bitrate that exceeds his max supported bitrate. That could cause the jumping your discribe.
If so then there's really nothing you can do (save re-encode at a lower bitrate). -
It could also be that your friend's DVD player doesn't support (S)VCD.
Its not really my friends dvd. It is mine, but in a different room. Like I said before it had no trouble before playing xsvcds at 3000kbps. The movie Iam trying to watch is only encoded at 950 so that I can fit it on two cdrs.
Rendering multiple framerates?
By Sephisto in forum Video ConversionReplies: 1Last Post: 8th Apr 2012, 13:46 -
Videos with different framerates need to be joined together
By vertigoelectric in forum Video ConversionReplies: 15Last Post: 18th Mar 2012, 04:21 -
Double PAL framerates, AVFS, and Vegas. Video playing back doublespeed.
By banditeer in forum EditingReplies: 13Last Post: 18th Oct 2010, 09:09 -
Synchronize audio and video with different framerates
By dexter30 in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 15:53 -
Framerates and converting to DVD
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 18th Jun 2007, 01:31
