All i want to do is take videos and put them on dvd. thats it. and i've spent a ton of money on programs. I have Ulead MediaStudio6.5 and DVD workshop1.3. First, i capture the clips using mediastudio and then edit them, then convert them in the same program. When i try to open them on dvd Workshop, the whole program shuts down without telling me what the problem is or anything. It will open up smaller files, but not the larger ones that ive edited. I'd apreciate the help. thanx
Chainsaw:
If all you want to do is take videos and put them on DVD then you've spent way too much money for such a basic task. Do you have any other software you can try the authoring with? For example, try the demo of DVD Movie Factory or try the $30 NeoDVD to see if they work. If your MediaStudio-created MPEG2 file works with other software, then DVD Workshop could be the culprit. Otherwise, there could be something wrong with the way MediaStudio encodes your MPEG2. -
DVD Workshop can capture and convert to MPG on the fly (so they say). It does work but you may find the quality less then what you can get elseware.
If you have Media Studio Pro and the DVD plug-in, you can create a DVD right in MSP. It's basically a stripped down version of DVD movie Factory.
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55 -
Video is upside down in DVD Workshop 2
By darkcyber in forum Authoring (DVD)Replies: 12Last Post: 7th Oct 2007, 22:22 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 10:16
