hey, I've been having trouble encoding this one movie. I have been trying to get it from avi to mpeg2 so I can burn it to dvd. How ever when I import it to tmpgenc, under the ntsc template it says that the movie is 300 minutes plus and the size will be 8000 megs plus. However the movie is only 1 hour and half. At first I decided to just try to encode it anyway but it wouldn't let me because it said that if it was pcm it couldn't exceed 300 min. So I choosed another audio and It let me, however half way through it errored. Anyone have any ideas?
"So let me get this straight, you pull it out and I suck?....is there any money in it for me"
Why Tmpgenc errored, probably bad frames. Look in the user guides forum for how to fix this.
As for the movie length, it probably has VBR audio which TmpGenc doesn't handle properly and often gets the length too long. Again, there is info in the user guides and all over the forum on how to fix this.
File size problems when playing from USB?
By BBQchicken in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Nov 2011, 19:26 -
Avidemux Target Size Problems
By FrozenInferno in forum Video ConversionReplies: 10Last Post: 2nd Apr 2011, 15:52 -
xvid target size problems
By Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 16:11 -
Problems With Video Size
By Jake802 in forum Video ConversionReplies: 2Last Post: 5th May 2008, 23:01 -
Size problems with DVDAuthorGUI
By supernano in forum Authoring (DVD)Replies: 5Last Post: 12th Sep 2007, 03:29
