I have a Sony DW-10A which is the OEM version of the DRU500.
The BIOS reports 1.1a firmware, which I thought might be a later version than the 0.1g.
After a bit of research, I found that the OEM firmware versions were different, and that the 1.1c is supposed to be the same as 1.1c.
I tried the upgrade, and the first bit was fine, and a the burner was recegnized, and I was prompted to reboot. On the second stage, the upgrade software reported that it could not update the firmware.
After several tries, it still would not update.
After powering the system down, the OS does not recognize the drive. Although the BIOS still recognizes it with 1.1a firmware.
Is there any way to recover this?
Brian
Results 1 to 1 of 1
Gerard
Encoding Failure
By artifaxx in forum Video ConversionReplies: 2Last Post: 3rd Jan 2012, 21:07 -
WD hdd failure
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2011, 08:33 -
laptop failure
By romanstopme in forum ComputerReplies: 6Last Post: 21st Feb 2010, 09:23 -
Burning Failure
By Em in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2007, 04:21 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 06:32
