Howdy
Say I created two mpeg 1 files both 20 mins in duration, both having 1150 as the bitrate (forget the audio for the minute), what difference to the physical size of the output file would there be if one was 352 x 288 (VCD PAL) and the other was 480 x 576 (SVCD PAL).
How do I calculate this? Is there a formula or maybe a freeware calculator I could use.
Kind regards
Alan
There wont be a difference of filesize.
@1150+224 both will be about 200 MB. -
Both files would be appx the same size. The size of the file it determined by the bitrate not the resolution.
Exactly.
total file size = bitrate * time
The framesize doesn't come into the picture. However, logically, increasing the framesize without increasing the bitrate means you essentially have less bits per pixel. This means reduced quality.
Regards.
Michael Tam
w: Morsels of Evidence
What's the relationship between image width, height and file size?
By coody in forum EditingReplies: 7Last Post: 13th Aug 2011, 02:55 -
Bitrate/QC same file size, is quality the same?
By marioval in forum DVD RippingReplies: 1Last Post: 4th Nov 2010, 08:56 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 19:28 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 17:05 -
Movie resolution, aspect ratio, quality, size, and compression relationship
By mario595 in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2010, 18:52
