i captured a video 10/12 years old with the audio dub at 20fps using divx 4 compression. The result was fairly grainy. what i'm trying to achieve is the same quality as the video. should i be using no compression or what other tips can be suggested re sizing or whatever ta.
Are you capturing at you highest resolution possible?
Hello. -
done at 320 x 240 pal. when i try to go larger (and what size should I use) i get an error message 418 unsupported, any idea why.
It might help a whole lot if you used no compression.Originally Posted by zappfra
Sounds like you have a Bt848 based capture card. You have to turn overlay mode off in order to be able to capture any higher than 352x288 resolutions in VirtualDub. Even better, turn even the Preview mode off (and capture blindfolded), CPU usage is much lower.done at 320 x 240 pal. when i try to go larger (and what size should I use) i get an error message 418 unsupported, any idea why.
If your source is PAL, capture at full PAL resolution (720x576) and 25 fps. Capture using a low compression codec (huffuv, PicVideo Mjpeg @ Q 19/20) and convert to DivX or whatever you want to only afterwards.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
AviSynth script to increase picture quality of VHS to DVD?
By VideoFanatic in forum RestorationReplies: 5Last Post: 30th Sep 2011, 08:33 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
vhs archiving-advice please
By mandywr in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2011, 13:34 -
Need advice about capturing VHS
By jimlong in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2008, 03:11
