I've been playing with the ATI TV Wonder recently and I'm a bit confused with the capture codecs.
According to the website, this thing is supposed to be able to capture in AVI and MPEG. However, the only choice I get when I go into options is VCR1.
This is odd because according to the website, VCR-1 and AVI are only for the TV Wonder VE which this is NOT.
Can anyone shed any light here?
There are lots of threads about how to capture MPEG's with your ATI and MMC - just do a little searching. It is possible to capture MPEG-1 and MPEG-2 plus AVI
I'm a little confused by your question - my first suggestion would be that you get the latest MMC from the ATI web site.
...also you can check out the link in my sig for a helpful tool "Next" and myself developed.
your pal,
Stinky -
Well, I did figure out how to do MPEG but not with sound. I am looking around the posts but I've been searching everywhere so I'm getting a little tired of reading
At any rate, the tool you mentioned is for AIW and I have a TV Wonder.
The other thing that bugs me is I can't seem to get VirtualDub or any third party utility to record with the TV Wonder. VirtualDub just bombs out....
More searching.... -
Z, your driver could only support DirectShow, but not VFW, hence all other 3rd part video capture progy won't work unless you install some files called VFW to DirectShow wrap or something, which I'm not formaliar with.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 12:57 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
