Hi, Im going crazy.
I have created a simple meny with Pinnacle 8.5 and then burnt it
with both Nero and Pinnacle studio. I still cant get the menu yo loop nor work at all. How hard can it be???
Pleeeeeease help me.
Matheus,
I have never used Pinnacle, but think that you cannot get a menu to loop with Nero.
Try using VCDEasy (freeware) this will allow you to use your short mpeg as a looping menu, plus you can allocate actions to the numbered buttons on the remote for your standalone DVD player. I do this all the time for VCDs and I can see no reason why it would not work for SVCD.
If you look in the guides to the left of this page, you should find one that helps with what you want to do, using VCDEasy.
Rgds -
--deleted by author--
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 12:37 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 07:32 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
TMPGEnc Authoring Works 4 Single Menu
By Sakuya in forum Authoring (DVD)Replies: 3Last Post: 22nd Dec 2009, 02:04 -
Is there CD/DVD menu creation softeware that works?
By Djard in forum ComputerReplies: 11Last Post: 14th Mar 2009, 17:46
