hi
i have been using tmpgenc for encoding from avi to mpeg 2 for svcd and find that although the video is of a good quality the audio produced from it is not that great...
is there anything else i can use to encode the audio while letting tmpgenc do the video...
thanks
get the toolame plugin for tmpgenc, then set it to work under option | environmental setting | external tool | layer 2...this is for the j version of tmpenc, maybe different in other versions
use Toolame with tmpeg for better (much better) encoding
Hi
I have had a few films with bad audio, and have loaded the "AVI" into http://www.goldwave.com (it takes the audio only).
Then you can normalize, make it stereo and get rid of hiss, before you finally save it as a WAV
Then Use TMPGEnc Video > AVI Audio > WAV
With a program like this you can see what's going on, and can experiment with the sound on screen. -
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-09-13 18:13:51 ]</font>
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 07:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 11:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 02:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
