and then the same cd will play fine in my computer's dvd-rom.
i make my vcd's with TMPGEnc. i've tried burning with nero and VCDEasy.
bad burner? bad codec? bad dvd player(dvd's play perfect)?
any ideas i'd very much appreciate it.
need more details.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
sounds pretty straight forward, your dvd player doesn't like that particular cd-media,try a different brand with the SAME exact settings and see what happens
"The software said Win XP or better, so I Installed Linux" -
like what exactly?
type of dvd player - JVC XV-S300
cd's - Imation and Phillips
Burner - Creative - 8-4-32
do you need specific TMPGEnc settings? -
i'd only suggest you buy a different type cd-r/rw like memorex, or fuji . take the same original file(from you hd) burn it to the new disks and try it. I had the same problem, my dvd player for some reason doesn't like "philips" brand cd's but almost all other brands work fine.
Are you making compliant VCD's. Are you altering the bitrate from the VCD standard? VCD's out of spec (XVCD's) won't play on some machines.
Also, try a lower burn speed maybe, like 2 or 4X."Art is making something out of nothing and selling it." - Frank Zappa
Cute video of Kitten sticking her arm out of box hole!
By peggypwr1 in forum Off topicReplies: 0Last Post: 27th Jul 2011, 21:52 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 17:21 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Help to convert high definition MKV video to DVD-Player compatible AVI file
By lovecraft123 in forum Newbie / General discussionsReplies: 27Last Post: 1st Mar 2008, 18:22 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50
