everytime I load tmpgenc to convert to to smaller size using tmpgenc it says can not support bmv.mpg do anyone know whats wrong
Results 1 to 17 of 17
A little more information might be helpful. Such as: what this bmv.mpg is and how you got it? Is it mpeg-1, mpeg-2? Did you download it, get it from a vcd, svcd, dvd, ect.? Even if you have no idea what it is or what it's from it would be good to mention that. If you have no idea what the examples are that I gave you I suggest you skim the glossary and newbie guides on the left; they are very helpful.
I am going to make an assumption that you may have downloaded it or got it from something like svcd and it is an mpeg-2 video file. Because mpeg-1 can usually work in tmpg and vdub if there isn't something else wrong. In that case you would have to either install an mpeg-2 codec then you should be able to open it in tmpg or run it through a program called DVD2AVI. Here is a guide for dvd2avi: https://www.videohelp.com/mpeg2tovcd.htm. Here is an mpeg-2 codec you could install: https://www.videohelp.com/tools.htm#codecs -
ok it was suppose to svcd movie and it was downloaded. I have the newest version of tmpgenc when I try to load it says bmv.mpg not supported. when I try to load the mpeg2 in the folder of tmpgenc it says LHA not installed options/configuration/program loaction dialog box. I cant get dvd2avi to load it also nothing seems to work. I have winXP
help help. I have beendoing this for a while and never had thiss problem -
do you have an mpeg2 codec?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Can you play it in a software player such as powerDVD or WinDVD. Because if you can't you might have a corrupted file and I don't think there is anything else you could do. Although, this brings to mind a time when my friend downloaded a clip and it wouldn't work with anything on his XP machine, but we burned it and tried on my ME machine and it worked. I have no idea what it was that made it not work, but you might try getting it to work on another computer if you can.
Its on my harddrive and I am trying to convert to a smaller mpeg file to play on dvd player like I have been doing for a long time. I use to could load the file in tmpgenc and everything was fine. Its not the only file that does this. the xvid works fine in tmpgenc. I just cant get the mpeg codec loaded in the tmpgenc folder ..
When you say the xvid works fine, do you mean you have an xvid of the same movie? If you do just use that to encode to a smaller mpeg.
no I am just saying for example thats all. the movie is the only version i have
because you said the xvid works fine. DO YOU HAVE A MPEG2 CODEC INSTALLED?
i have downloaded it but was not successful putting it in the tmpgenc folder. i need help with that
thanks for the help I am just gonna use totalrecorder to convert to wav file. I just was looking for a quiker way using tmpgenc thanks though
wav? are you trying to make a movie or a sound file?
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 16:52 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07 -
MPG with TMPGEnc
By koberulz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 17:43 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 01:52
