I have limited hd space (8gb) and I am currently producing a video, the end product i want to produce to svcd. Which is the best format to capture to considering i will have to sort through roughly 3 hours of raw footage to edit in Premiere. Also could someone give me some size comparisons for a min or so of video (eg. how big is 1 min of uncompressed avi???)
Thanx for the help.....
Also if you if you run Virtual Dub, it tells you the kbytes/s you'll need as you change the setup. This is a good way to predict size. Also using the huffyuv codec you can expect atleast 2:1 compression of that number.
If you want to capture at a high resolution at 30fps, I would strongly suggest you buy a new HD. 40GB are ~$75 online and 60GB drives are $100~125. Even Best Buy and Costco have pretty good prices on drives.
The thing is that even thou it possible to work on an 8GB drive by cutting/pasting everything together it's a huge pain in the ass. Don't forget you'll have to capture in chunks, encode in chunks, (somehow store the chunks), repeat several times, then get only the encoded MPEGs on your HD, splice them into one file (which will generate a file slightly greater then the sum of all the smaller ones), etc. etc.
I don't say this is dash your plans, but because I use to do stuff like this and it's not worth the $100 to buy a bigger HD
Luck...
Best format to capture in?
By Canopus Smoker in forum Newbie / General discussionsReplies: 10Last Post: 27th Nov 2008, 15:14 -
what is the best format when capture from tv show?
By sumeshkri in forum Capturing and VCRReplies: 10Last Post: 23rd Feb 2008, 19:35 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42 -
WMV Format Capture
By zerohash in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 09:48 -
best capture format and software
By boots in forum Capturing and VCRReplies: 11Last Post: 27th Jun 2007, 20:54
