hi guys,
I just cant get TMPGE to convert a 16:9 format AVI file, to 16:9 MPEG 2 file.
it does convert the AVI, but always to 4:3 no matter what settings I try
ive selected the source as both 4:3 , and 16:9, but either way, it still outputs to 4:3
also, I have tried the output file set to both 16:9 and 4:3 formats
basically, it always make the new MPEG file 4:3, regardless of what i set it to
any ideas ?
its driving me nutz !!!
cheers
Buganna.![]()
You need to set both source and TARGET to 16:9 (Target is the Video Tab, "Aspect ratio" pulldown).
You may also want to try making sure that on the Advance tab that Video Arrange Method is set to "Full screen(Keep aspect ratio)
I think you need to set your source aspect ratio to 1:1. That doesn't mean that it's a square picture it just means that the pixels are square and not stretched. For instance, a 4:3 DAR mpeg file with 720x480 resolution will look the same size, aspect ratio, ect. as a 1:1 DAR mpeg file or an avi with 640x480 resolution (640/480=4/3).
thanks everyone !!
i used your methods and it now works fine !
the main thing i did not do, was 'KEEP ASPECT RATIO' under ADVANCED menu....
I did not even know about these options !
thanks again
Buganna
:P
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
