Can anyone out there help me ? I am trying to make my SVCD MPEG2 Stream compliant for DVD authoring and I am not having any luck...
Please post your replies here, your help would be appreciated.
thanks
If you tell us what you are actually doing we might be able to tell you what you are doing wrongOriginally Posted by dvdfreakagain
You know, what is your source (SVCD but is it complaint), what tools you are using, templates settings etc, and what is actually going wrong would be a good start. -
If you want the SVCD to be DVD-compliant, make sure the audio is at 48000Hz.
https://www.videohelp.com/svcddvdr.htm
The DVD standard calls for MPEG2 video at 720x480, 352x480 or 352x240 with either PCM or AC3 audio at 48khz.
SVCD white book calls for MPEG2 video at 480x480 and mpeg2 layer I audio at 44.1khz.
The above link allows you do a 'header trick' to make the 480x480 video read as 352x480 (other wise you HAVE to re-encode to a DVD acceptable resolution). It also tells you how to re-encode the audio to 48khz. Although mp2 audio is NOT part of the DVD standard, most (MOST not all) standalones will have no trouble playing it. If you'r DVD player does then you'll want to convert your audio from MP2 to AC3 (PCM takes up to much space). -
Cough Cough..
x264 GUI specifically for blu-ray compliant elementary streams
By turk690 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Apr 2012, 19:20 -
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 19:06 -
Suggestions for DVD authoring with multiple audio streams
By farmkid in forum Authoring (DVD)Replies: 11Last Post: 19th Sep 2011, 17:23 -
Movie freezes after authoring compliant DVD files
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 21st Dec 2007, 10:29 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 15:35
