is there 'Any way to copy a copied DVD to VCD?'
i have tried and tried but the copy software (have tried many) won't recognise the copied dvd as a dvd so it won't copy it.
any advice and i would be grateful
many thanks
just use the original dvd.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
unless you do that ol' "rent-n-rip".
Then unless its a homemade DVD (which you have stated it is not because you don't have the "original") that is illegal to own it
A 'copied' DVD still should owrk in your PC just as the original did..unless you authored it wrong to start with or unless the media is less than perfect and your drive is having probs reading it.
You could use something like flask to make a VCD from a dvd..althoughwhy would u want to ?
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 09:12 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 12:56 -
Extent of copy protection...and ability to tell is a DVD has been copied
By SM9 in forum Newbie / General discussionsReplies: 29Last Post: 26th Jul 2008, 05:16 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 04:50 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 08:16
