I'm really getting desperate here. I am trying to join two large .avi files into one large file and nothing is working for me. They are the same resolution and framerate, as well as the same codec (XviD, I think). They play perfectly in mplayer, but in quicktime there is no sound unless run thru DivX Doctor II or DivX Validator, and even then the sound is choppy (this seems to be the case for a lot of PC encoded avi's which is why I play them in mplayer). When I use DivX Tool to extract the mp3 soundtrack, it plays choppy as well. This has pretty much prevented me from Option 1 which is just joining them in Quicktime Pro.
So, I tried using some Windows programs in VPC. AVI joiner just gives me a 'cannot join' message and EZ joiner doesn't seem to work. Therefore Option 2, Virtual PC doesn't seem to work either. I hate using Windows anyway.
The 'Split me' program for OS X looked promising but doesn't seem to work for anyone. It uses mencoder, so I thought I'd just go into the commandline and try to do this manually using the directions here: http://www.mplayerhq.hu/DOCS/encoding.html#fixing. This gives me a bunch of errors and then quits. I think Option 3, using mencoder, is the most promising, but I still don't understand mencoder well enough to get it to work.
So, I'm out of options, but I thought maybe there's someone out there who has done this, either in OS X or VPC who could help me out. Thanks guys.
Nick
Could this help?
cat file1 file2 > file3
mencoder -ovc copy -oac copy -o out.avi -forceidx file3.aviThomas -
This is really easy to do with mencoder in the Terminal.app
You're posting I hope so someone will let us know this can be done while maintaining sync -
Yep, the syncing sure is a problem.
I tried to use D-Vision 2 to do the same, but the movie goes out of sync.Thomas -
use FFMPEGX
go to TOOLS, then to 1st browse field, choose the 1st .avi
use 2nd browse to choose the 2nd .avi
click JOIN -
Originally Posted by ZeroSix
Believe me. I have just asked major4 about it, and this is what he said:
"Splitting is a complicate operation with the mpeg format and the above method using mencoder is not perfect. I'm looking for better methods to be implemented in future versions.
btw... joining is more critic and prone to error than splitting."
If you have downloaded splitted AVI files from the net, that are splitted on a PC (with better tools) you get good video/audio sync when you join with ffmpegX (the mencoder method). The problem is if you split your AVI files your self, with the mencoder method, and then try to join them again. Then you get a bad resultThomas -
thats why you shoudl always demux/remux a split/join file
How do I losslessly join 2 DV-AVI files?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2010, 11:07 -
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 03:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 22:56 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
