Hi there,
Recently I downloaded some .mpg files. I thought I would be able to burn them as VCD with Toast. But it wasn't available. Whenever I drag-n-drop them to Toast it says:
"File cannot be used to create a VideoCD. Please use the 'Video CD' option in your MPEG encoder/multiplexer"
Then I tried to export the mpg file as "Toast Video CD". It was not succesful, either. It gave the following error:
"Couldn't export the movie. Because there is no video track"
I saved the as .mov and tried the same mpg conversion. Same error was occured.
Please advise what I should do.
Quicktime file info: Format- MPEG1 Muxed
Platform: OS 10.2.4, G3-700, 60 GB HD, 1GB ram
Thanks 8)
Results 1 to 1 of 1
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
