Video with xvid aren't playing in wmp 9. I have three total all three crash in wmp9 with the we have encounter a problem and will close.
One of the three will play in bsplayer but when I go to put it in tmpge it tell me it has encounter a problem and will close.
All three movies in gspot tell me I have all the codec installed!
I have installed TSUNAMI-filter -pack-full and xvid codec koepi's installed.
All three movie are full complete.
Results 1 to 9 of 9
try ffdshow : http://www.doom9.org/index.html?/software2.htm
its about halfway down the page.
try the ffdshow no go. notice when I instert the film in tmpge to convert there is no audio.
could this be the problem?
in gspot under audio format it says
ac3 (0x2000) "Dolby Laboratories, Inc"
codec is installed
under directshow render is say
4cc: XVID video media
video codec is ffdshow MPEG-4 Video Decoder
audio codec is AC3 from AVI XForm --> InterVideo Audio Decoder-->Morgan Stream Switcher
don't know why if all the codec are install it won't open in tmpge and when I try to make a wav files in vdub tell me no audio decompressor can be found>
thanks -
Originally Posted by rst1953
sounds like your missing some codecs. my best advice is to un-install,then re-install all your codecs. if it still dosen't work, then you are missing some codecs. i know its kind of a pain,but as a general rule,if the audio or video is missing=missing codec/s
p.s. what is your O.S. cause wmp9 won't run right below win98se. -
uninstalled my codec ( I hope)
installed xvid video encoder 04120002-1 kopie's build.
when I go into mediaplayer 9 tell me it cann't find the codec.
any go codec packages I should download also.
thanks -
try nemo,available in the tools section. just follow the instructions when installing.
Hi ppl!
I have a similar annoying problem:
Avi with ac3 sound won´t play in WMP 9. WMP 9 reports an error in AppName: wmplayer.exe, AppVer 9.0.0.2980 and ModName: ac3audio.ax, ModVer: 2.2.0.0, Offset: 0001121d (if these are of any help) This error report follows a total program crash and shut down and naturally I´m not able to watch the video.
Have many common codecs installed (XviD, DivX 3.11, 4, 5,) and video + audio work fine while playing these. Tried installing Nemo 433, Nemo Pack 5 Build7 and someother AC3 audio upgrades but always the same error report and crash!
I use Windows XP and uppgraded recently to WMP 9.00.00.2980
Please give me an answer to what is causing this problem???
Tnx
Rob
Playing video to Google TV
By Boomn4x4 in forum Video Streaming DownloadingReplies: 2Last Post: 18th Jan 2012, 21:34 -
Video Playing problem....
By Amirul Izzad in forum RestorationReplies: 1Last Post: 13th Dec 2011, 04:31 -
Scheduled Video Playing
By gooberguy in forum Software PlayingReplies: 1Last Post: 11th Oct 2010, 15:40 -
New to Video Editing, Need to ad an image while the video is still playing.
By MichaelHarman in forum EditingReplies: 3Last Post: 16th Mar 2010, 09:37 -
no video but sound playing video with MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 30th Mar 2008, 04:05
