i just go the movie Ditto and it is an AC3 file
i opened it on TMPG to convert and it didn't have the wav file in the project wizard
so i used virtual dub and when i did
a warning thing pops up and says
The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format.
Extract the audio with virtualdub using direct stream copy mode, then rename the extension to .ac3
Then use Besweet to convert the ac3 audio to WAV audio....you will then be able to use it as the audio source in TMPGenc. It sounds a lot of work but its the only way you can encode a movie with ac3 audio. -
And make sure you have the AC3 codec, you can test it with Gspot if you're not sure. It's in the Tools section.
Voice Over / Dubbing
By evil nemesis in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 17:21 -
Dubbing problems with LG
By normp in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 09:10 -
Problem: No dubbing from Sony HD camcorder to hard drive of HDD
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Feb 2010, 22:43 -
Dubbing in audio to DVD
By jimlahey in forum AudioReplies: 1Last Post: 28th Jul 2008, 15:14 -
Dubbing from VHS to MiniDV
By markannab in forum Capturing and VCRReplies: 5Last Post: 29th Jul 2007, 07:46
