I have just bought a NEC ND1000a DVD+R/W drive, and I cant get it to burn properly, It burns CD-R's perfectly but when I try to burn a DVD+r I get the message "power calibration error" i've tried using different burning software, and using the latest ASPI files but it doesn't want to work most time, I have burned just 2 DVD's and every single other attempt has failed, anybody got any ideas? should I take it back to the shop? or is it a simple prob to fix?
it seemthat the ND-1000a seems to only exept good quility DVD+r if you use cheaper ones thats when you get the power calabration error it seem like its down to firm ware i used bulkpaq DVD and every one came up the same error http://www.bulkpaq.co.uk/ have a look it seemes its not the only wrighter that suffers from the same problem on that sight it explains the problem a bit better look at the pioneer one in the info bit im thinking of sending mine back ive sent a email to nec but thay will probarly not repley but if thay do ill let ye know whats happning + i didnt know you can burn DVD-r in the nec ND-1000a are you sure a thought it was just +r it took but mind u im new to this
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 15:23 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
these drives only burn + surely can anybody confirm they burn _ +discs
