  1. It seems like Instatn can't copy Matrix(pal) right. Everything works perfect until the scene where Neo show all his weapons for the polices/guards and then shot them all down. In this scen it starts to hang and it play the scen two times, like a replay(very weird!). I have test the movie twice with instant, same problem both times. After this scen it continue to hang and play some scens twice.....
    Have anyone succed to backup MATRIX pal right?
    Wonder if it have something to do with this new version of Instant maybe, but I can't realy understand. Most be something wrong with Instant anyway!!!
    Feb 2003
    St. Louis, MO
    was it a glitch in the Matrix?
    Use what works for you...
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    basically Instantcopy cannot handle some multiangle movies correctly and these are the repeated scenes you are seeing
    If you play back just the original VOB you will see certain sections contain repeated segments, these are the white rabbit scenes
    if you wanna fix this, try my fixing suggestion over on DOOM9 for now until I find an even quicker way to fix the IFO's. Takes about 2 mins usertime and 15 mins or so processing to fix
    http://forum.doom9.org/showthread.php?s=&threadid=49955
