I normally compress the video with vidomi, then axtract the audio with dvd2avi and the with sound forge i give it loud volume and have a better wav file, then with VD join and compress both files, audio and video and then have a great divx movie in a cd. my first question is: i would like to have subttitles inluded in my movies but i don't know how? and the other question is about vcd format, i mean, i use tpmgenc to encode, what i do is to open the video file made by vidomi and open the wav file made by Sound forge and then encode and get mpeg file and burn the mpeg file with VCDeasy, but, this new DAT file is larger in difference with divx that i only needed one cd, now i need two cds, what can i do to make fit in one cd?
Thanks a lot!!!
ok, i already found the solution for the one cd fit problem(https://www.videohelp.com/forum/images/guides/84759/Image14.png)
about the subtitle for the divx?.
