Do you always have to check a film for bad frames first b4 encoding?
If so how many bad frames are acceptable b4 just deleting the film and trying another version as i have downloaded xXx and there was over 200 'bad frames' and 2000 'masked frames'
As in the guide to converting to VCD checking for bad frame was not mentioned.
it is ALWAYS a good idea to check for bad frames before converting.Originally Posted by ManWithaPlan
with that number of bad frames,you probably wouldn't even notice the difference. -
Here's a guide for taking out bad frames frames with VirtualDub:Originally Posted by ManWithaPlan
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
Yes, I always check for bad frames first to avoid major problems later.Originally Posted by ManWithaPlan
You're going to lose 2000 frames or about 80 secs. of video. That's not too bad, I've seen a lot worse! It's really your choice, but in this case you probably won't even notice.
I wish some of the guides would include advice to scan and delete bad frames first. It would help beginners avoid lots of problems and cut down on repetitive posts in the Newbie Forum. (Baldrick, are you listening?)"Art is making something out of nothing and selling it." - Frank Zappa -
When you say i wont notice the difference do you mean just encode it anyway with the bad frames present, or do you mean use vdub to remove them first?
When i used vdub to remove them and then tried to encode, TMPGEnc kept frezzing and i got this error ,TMPGEnc has caused an error in DIVXDEC.A.X.
I used vdub 1.4 not he vdubmp3, which method is better cos the vdub 1.4 seems easier to use than the other one?
I then decided to encode the film with the bad frames and it encoded first time and the copy wasnt that bad. -
Remove the bad frames first.Originally Posted by ManWithaPlan
Yes regular Vdub is easier, but if you have VBR sound then regular Vdub cannot be used, and you must use Vdub-MP3 and manually edit out the bad frames. However, you can use Vdub-MP3 on non-VBR files and some people think it is better. 8)Originally Posted by ManWithaPlan"Art is making something out of nothing and selling it." - Frank Zappa
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
