Hi! Does anyone know how to minimise or avoid dropped frame during capturing via a firewire card. Please advise!
Have a fast anuff hard drive with plenty of space and defrag the hard drive before using it or just very often, and have anuff ram and i cant think of anything else. if your pc has a scsi port i would suggest getting a scsi h/d for capping files i use a 15,000rpm seagate h/d for capturing video and editing but it is very costly
and also make sure there are no programs running that dont need to be like virus scan and such.
Do a (quick) format of the drive you use before each capture and use it for just that = capture, no storage, no nothing.
Also, fill in your forum computer profile so we can see what chances you have of success
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
If you have IDE, use a dedicated hard disk for video capture and connect it to it's own channel. If you have a slow processor, capture it in AVI and encode it using offline encoder ( on the fly software encoding takes up a lot of CPU time ).
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
How to avoid Generation Loss as much as possible?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 16th Sep 2008, 18:51 -
What is PVOP and how do I avoid it?
By Strumpah in forum EditingReplies: 4Last Post: 12th May 2008, 19:04 -
How do you avoid banding?
By zanos in forum MediaReplies: 3Last Post: 13th Mar 2008, 22:57
